メインコンテンツにスキップ
Nvidia Shield Tablet K1 WIFI Antenna Replacement
必要な工具と部品
  1. Nvidia Shield Tablet K1 WIFI Antenna Replacement, Back Panel: 手順 1、 1の画像 1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 2、 2の画像 1 Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 2、 2の画像 2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
  3. Nvidia Shield Tablet K1 WIFI Antenna Replacement, WIFI Antenna: 手順 3、 1の画像 1
    • Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
    • Make sure you disconnect the right cables. There are three of these.
  4. Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 4、 1の画像 1
    • Remove the screw adjacent to the WIFI Antenna using the J000 Philips head screw-driver.
    • Screw description: short black screw 20 mm length and 30 mm diameter.
  5. Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 5、 1の画像 1
    • Using the angled tweezers, begin removing the antenna from the device.
  6. Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 6、 2の画像 1 Nvidia Shield Tablet K1 WIFI Antenna Replacement: 手順 6、 2の画像 2
    • The black plastic piece of the antenna is attached to a copper colored film which can be pulled up using the tweezers.
    • The antenna should now be free from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
James Upchurch
メンバー登録日: 02/09/16
658 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 7-7, Cagle Spring 2016 USF Tampa, Team 7-7, Cagle Spring 2016人のメンバー
USFT-CAGLE-S16S7G7
3 メンバー
9のガイドは作成済み
コメント 1 件
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
Justin Mosimann - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 4,781
