はじめに
A camera lens on any device is naturally exposed to the elements of nature to obtain the clearest photo; however, this leaves the lens susceptible to damage and cracking. Cameras are used extremely frequently, especially on a device as portable as the Nvidia Shield Tablet. Follow this guide to replace both cameras on your tablet.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Set the tablet so the buttons, microSD, and stylus port are facing you.
Open the microSD slot.
Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
Orient your tablet so that the top of the tablet is furthest away from you.
Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
Having removed the speaker, locate the front-facing camera resting just underneath the speaker.
The rear-facing camera is on the left side of the tablet and it aligns with the camera hole on the back casing of your tablet.
ある他の人がこのガイドを完成しました。
