はじめに
Every gamer knows how important triggers are for our gaming experience. So, if your Nvidia Shield Pro Android TV Controller triggers are sticking or aren't functioning properly, then you need to replace your controllers’ triggers. Luckily, you're in the right place, this is an easy to follow guide and there are no special skills required. The goal of this guide is for you to be able to properly replace the controllers’ triggers, so you can go back to enjoying your games. Although, please be cautious when disconnecting the wires and gently apply pressure to thumbsticks when removing so nothing gets damaged. Lastly, Two different screwdrivers will be used, so if you're unfamiliar with them, then please refer to this link for Screwdriver Best Practices.
必要な工具と部品
Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
Gently lift the motherboard from the controller housing.
1件のガイドコメント
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
