メインコンテンツにスキップ
Nvidia Shield Pro Android TV Controller Triggers Replacement
必要な工具と部品
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 2 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 2、 1の画像 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 3、 2の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 3、 2の画像 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 4、 2の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 4、 2の画像 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 5、 2の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 5、 2の画像 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 手順 6、 3の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 手順 6、 3の画像 2 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 手順 6、 3の画像 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 7、 3の画像 1 Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 7、 3の画像 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 手順 7、 3の画像 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
終わりに
作成者
2人の作成者と共同で作成されました。
Jared Campbell
メンバー登録日: 02/16/22
85 ポイント
1ガイドが承認済み
コメント 1 件
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 283
