メインコンテンツにスキップ
Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
必要な工具と部品
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 1 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Bluetooth Controller Thumbsticks: 手順 1、 3の画像 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 2、 1の画像 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 3、 2の画像 1 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 3、 2の画像 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 4、 2の画像 1 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 4、 2の画像 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 5、 2の画像 1 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 手順 5、 2の画像 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Controller Rumble Motor: 手順 6、 3の画像 1 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Controller Rumble Motor: 手順 6、 3の画像 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Controller Rumble Motor: 手順 6、 3の画像 3
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
終わりに
作成者
1人の作成者と共同作成されました。
Andrew Boyce Hanson
メンバー登録日: 02/11/22
73 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 164
