メインコンテンツにスキップ
Nvidia Shield Joystick Replacement
必要な工具と部品
  1. Nvidia Shield Joystick Replacement, Remove Front Panel: 手順 1、 3の画像 1 Nvidia Shield Joystick Replacement, Remove Front Panel: 手順 1、 3の画像 2 Nvidia Shield Joystick Replacement, Remove Front Panel: 手順 1、 3の画像 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Joystick Replacement, Remove Green Grill: 手順 2、 2の画像 1 Nvidia Shield Joystick Replacement, Remove Green Grill: 手順 2、 2の画像 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Joystick Replacement, Remove Battery Cables: 手順 3、 3の画像 1 Nvidia Shield Joystick Replacement, Remove Battery Cables: 手順 3、 3の画像 2 Nvidia Shield Joystick Replacement, Remove Battery Cables: 手順 3、 3の画像 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Joystick Replacement, Remove Battery Apparatus: 手順 4、 1の画像 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Joystick Replacement, Removing Fan: 手順 5、 3の画像 1 Nvidia Shield Joystick Replacement, Removing Fan: 手順 5、 3の画像 2 Nvidia Shield Joystick Replacement, Removing Fan: 手順 5、 3の画像 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Joystick Replacement, Removing Logic Board: 手順 6、 3の画像 1 Nvidia Shield Joystick Replacement, Removing Logic Board: 手順 6、 3の画像 2 Nvidia Shield Joystick Replacement, Removing Logic Board: 手順 6、 3の画像 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
  7. Nvidia Shield Joystick Replacement, Removing Joysticks: 手順 7、 3の画像 1 Nvidia Shield Joystick Replacement, Removing Joysticks: 手順 7、 3の画像 2 Nvidia Shield Joystick Replacement, Removing Joysticks: 手順 7、 3の画像 3
    • Unscrew the 3 6.5mm screws from the Joystick board
    • Unplug the ribbon attached on the right hand side of the board
    • Once removed, the Joystick board will lift from the panel, allowing replacement
    • The thumb-Sticks can be pulled off of the metal pegs for replacement.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Barbanera
メンバー登録日: 09/20/14
376 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G1
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 27
今までの合計 4,158
