パーツ
パーツは必要ありません。
Unscrew the 7 6.4mm T5 Torx screws from back panel
Use spudger to separate front and back panels
Remove the 6 6.5mm T5 Torx screws.
Remove power wires.
Peel back copper tape and remove black and white wires.
Cooling is important for electronics, the last thing they want is to overheat.
Remove the two 7.3mm and four 8.4mm T5 Torx screws and remove the power cable.
Once the screws and cable are removed, the fan can lift free
The large board under everything is the logic board.
Removing this requires unscrewing 6 screws, 2 7.3mm T5 Torx and 4 8.4mm T5 Torx located around the edges of the logic board, which should have already been taken out when removing the fan.
Once all the screws are gone, be careful with the ports on top of the logic board. Gently wiggling helps.
Unscrew the 3 6.5mm screws from the Joystick board
Unplug the ribbon attached on the right hand side of the board
Once removed, the Joystick board will lift from the panel, allowing replacement
The thumb-Sticks can be pulled off of the metal pegs for replacement.
4 の人々がこのガイドを完成させました。
コメント1件
Does anybody know where to get these types of thumbstick replacements? I looked everywhere and I can't seem to find them.
