メインコンテンツにスキップ
Nvidia Shield Display Assembly Replacement
必要な工具と部品
  1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 1 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 2 Nvidia Shield Display Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - 返信
  2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: 手順 2、 2の画像 1 Nvidia Shield Display Assembly Replacement, Remove Green Grill: 手順 2、 2の画像 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 1 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 2 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: 手順 4、 1の画像 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Display Assembly Replacement, Removing Fan: 手順 5、 3の画像 1 Nvidia Shield Display Assembly Replacement, Removing Fan: 手順 5、 3の画像 2 Nvidia Shield Display Assembly Replacement, Removing Fan: 手順 5、 3の画像 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: 手順 6、 1の画像 1
    • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
    • Once removed, the display should be able to be detached.
    There is also a screw holding down the ribbon cable to the main board. which needs to be removed prior to display assembly removal.
    Miles Raymond - 返信
    Any one know size of screw holding down ribbon cable?
    tgl030 - 返信
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Noel Fletcher
メンバー登録日: 09/22/14
116 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G1
4 メンバー
18のガイドは作成済み
コメント 1 件
Where can o get a replacement screen
jorge valenzuela - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 6,427
