メインコンテンツにスキップ
Nvidia Shield Battery Assembly Replacement
必要な工具と部品
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 1 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 2 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 手順 1、 3の画像 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - 返信
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 手順 2、 2の画像 1 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 手順 2、 2の画像 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 1 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 2 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 手順 3、 3の画像 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: 手順 4、 1の画像 1
    • Pull the battery apparatus out once all cables are removed.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Andrew Barbanera
メンバー登録日: 09/20/14
376 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G1
4 メンバー
18のガイドは作成済み
4 件のコメント
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - 返信
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - 返信
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - 返信
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 49
今までの合計 6,007
