メインコンテンツにスキップ
Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement
必要な工具と部品
  1. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: 手順 1、 1の画像 1
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 2、 2の画像 1 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 3、 1の画像 1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 4、 3の画像 1 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 4、 3の画像 2 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 4、 3の画像 3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 5、 1の画像 1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the phillip's screws from the motherboard.
  7. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 7、 1の画像 1
    • Flip the motherboard over.
  8. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove any plugs from the motherboard.
  9. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 手順 9、 1の画像 1
    • Desolder wires and cords. Replace old motherboard with new one, and resolder wires and cords.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Will Jones
メンバー登録日: 09/26/17
155 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S7G1
5 メンバー
6のガイドは作成済み
コメント 1 件
Hello Will - thank you for that lesson. I am from Canada, going to CUBA and my Cuban friend needs the motherboard for a similar blender (BL 770-2.) Where do I buy one? Thanks.
Judith Falardeau - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 1,121
