メインコンテンツにスキップ
Nuphy Air75 Keyboard Switch Replacement
必要な工具と部品
  1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: 手順 1、 2の画像 1 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: 手順 1、 2の画像 2
    • Place your keyboard on a clean, well-lit surface.
    • Slide the keyboard power switch to the "off" position.
  2. Nuphy Air75 Keyboard Switch Replacement: 手順 2、 3の画像 1 Nuphy Air75 Keyboard Switch Replacement: 手順 2、 3の画像 2 Nuphy Air75 Keyboard Switch Replacement: 手順 2、 3の画像 3
    • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
    • Pull gently until the key cap comes off.
    • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
  3. Nuphy Air75 Keyboard Switch Replacement: 手順 3、 3の画像 1 Nuphy Air75 Keyboard Switch Replacement: 手順 3、 3の画像 2 Nuphy Air75 Keyboard Switch Replacement: 手順 3、 3の画像 3
    • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
    • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
    • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
  4. Nuphy Air75 Keyboard Switch Replacement: 手順 4、 2の画像 1 Nuphy Air75 Keyboard Switch Replacement: 手順 4、 2の画像 2
    • Orient the replacement switch so that the colored, circular module is facing up.
    • Gently press down until you hear an audible click.
    • Place the keycap over the newly installed switch and gently press down.
  5. Nuphy Air75 Keyboard Switch Replacement: 手順 5、 2の画像 1 Nuphy Air75 Keyboard Switch Replacement: 手順 5、 2の画像 2
    • Turn the power switch to the "wired" or "wireless" position depending on your setup.
    • Test your keyboard and new key switch.
ゴール
作成者
3人の作成者と共同で作成されました。
Brad
メンバー登録日: 01/16/24
121 ポイント
1ガイドが承認済み
チーム
Northern Arizona University, Team 1-5, Konrad Spring 2024 Northern Arizona University, Team 1-5, Konrad Spring 2024人のメンバー
NAU-KONRAD-S24S1G5
4 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 129
今までの合計 2,448
