メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. Flip over the turntable and remove the 9 screws on the outer edges. Flip over the turntable and remove the 9 screws on the outer edges.
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Remove the back cover by pulling it apart.
    • Remove the back cover by pulling it apart.
  3. Remove the clip located on the backside of the audio jack housing by gently pulling it out. There will be some resistance but continue to pull gently. The clip is located right underneath the audio jacks.
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing. Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  6. Gently pull the wire that you just unscrewed to release it from the clip. Gently pull the wire that you just unscrewed to release it from the clip.
    • Gently pull the wire that you just unscrewed to release it from the clip.
  7. Remove the two screws connecting the circuit board to the tone arm. Remove the two screws connecting the circuit board to the tone arm. Remove the two screws connecting the circuit board to the tone arm.
    • Remove the two screws connecting the circuit board to the tone arm.
  8. Remove the two remaining screws connecting the tone arm to the device. Remove the two remaining screws connecting the tone arm to the device.
    • Remove the two remaining screws connecting the tone arm to the device.
  9. Flip the turntable back over to the top side.
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  10. Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver. Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand. Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  11. Pick up the tone arm and point the back end of it towards its base. Push the back end of the tone arm into the hole. Flip the turntable over and pull the tone arm all the way through the hole.
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
終わりに
2 の人々がこのガイドを完成させました。
Nikolai
メンバー登録日: 2011年10月12日
161 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G14
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 111
今までの合計 5,749
