この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
After many charging cycles, your battery can wear out and eventually lose its ability to hold charge. When that happens, you will need to replace the battery to keep using your Mifi.
必要な工具と部品
Remove the rear cover by pressing down on the cover and pulling it away from the device.
もう少しです!
Charge your new battery and you are ready to use your Mifi again.
終わりに
ある他の人がこのガイドを完成しました。
