はじめに
Connection problems may occur with this device due to a faulty or broken antenna. You can contact your service provider or search online to purchase a new antenna to replace. This guide give instructions on how to replace antenna.
必要な工具と部品
Remove the rear cover by pressing down on the cover and pulling it away from the device.
To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
