はじめに
This guide will show you how to replace a faulty SD Card in your Novatel Hotspot device. This requires opening the rubber flap and removing the old SD Card.
Note: This guide does not feature an actual SD Card.
Unplug the charger from your Novatel Hotspot device.
Place the Novatel Hotspot device face down on a flat, clean surface.
Locate the rubber SD Card cover on the bottom left hand side of the device. The cover is labeled “Micro SD.”
もう少しです!
終わりに
