メインコンテンツにスキップ
Nostalgia Electrics RHP-310 Power Switch Replacement
必要な工具と部品
  1. Nostalgia Electrics RHP-310 Power Switch Replacement, Power Switch: 手順 1、 1の画像 1
    • Unplug the popper.
    • Remove the plastic lid by lifting the lid up.
  2. Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 2、 1の画像 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 phillips head screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 phillips head screwdriver.
    • Save the screws you remove from the base in a safe place. They will be needed to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 3、 1の画像 1
    • Flip the base to view the interior surface of the base.
    • Unscrew the two screws (10 mm Philips #2 screws) from the base.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 4、 2の画像 1 Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 4、 2の画像 2
    • Locate the power switch connected to the side of the housing.
    • Carefully pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 5、 1の画像 1
    • Now that the power switch is removed from the housing, you must remove the wires connected to the power switch.
    • Use the plastic opening tool to gently pry the wires loose from the power switch.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Power Switch Replacement: 手順 6、 1の画像 1
    • Remove the power switch from the device.
    • You can now replace the power switch if necessary.
終わりに
作成者
9人の作成者と共同で作成されました。
Dana Clarke
メンバー登録日: 09/26/12
50 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G57
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 1,004
