メインコンテンツにスキップ
Nostalgia Electrics RHP-310 Disassembly for cleaning
必要な工具と部品
  1. Nostalgia Electrics RHP-310 Disassembly for cleaning, Power Switch: 手順 1、 1の画像 1
    • Unplug the popper.
    • Remove the plastic lid by lifting the lid up.
  2. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 2、 1の画像 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 phillips head screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 phillips head screwdriver.
    • Save the screws you remove from the base in a safe place. They will be needed to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 3、 1の画像 1
    • Flip the base to view the interior surface of the base.
    • Unscrew the two screws (10 mm Philips #2 screws) from the base.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 4、 2の画像 1 Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 4、 2の画像 2
    • Locate the power switch connected to the side of the housing.
    • Carefully pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 5、 1の画像 1
    • Now that the power switch is removed from the housing, you must remove the wires connected to the power switch.
    • Use the plastic opening tool to gently pry the wires loose from the power switch.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 6、 1の画像 1
    • Remove the power switch from the device.
    • You can now replace the power switch if necessary.
  7. Nostalgia Electrics RHP-310 Disassembly for cleaning, Replacing Housing: 手順 7、 2の画像 1 Nostalgia Electrics RHP-310 Disassembly for cleaning, Replacing Housing: 手順 7、 2の画像 2
    • Now that the power switch is disconnected from the popper, you will need to remove the white top.
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
  8. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 8、 1の画像 1
    • Remove the white top from the housing.
    • Save the screws from previous step. You will need them to connect the new housing to the white top.
  9. Nostalgia Electrics RHP-310 Disassembly for cleaning, Replacing Fan: 手順 9、 1の画像 1
    • Now that the white top is disconnected from the housing, remove the heating component from inside the device.
  10. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 10、 1の画像 1
    • Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
  11. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 11、 1の画像 1
    • Make sure to keep the screws. You will need them to put the heating component back together.
    • Pull the heating component apart.
  12. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 12、 2の画像 1 Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 12、 2の画像 2
    • Locate the fan.
    • Pull the fan off the motor firmly but gently.
    • When you pull the fan off the motor, be careful. Do not pull to hard or you will break the motor.
  13. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 13、 1の画像 1
    • You can now replace the fan.
    • If there is debris stuck in the fan, you can easily clean it out from the fan in this step.
  14. Nostalgia Electrics RHP-310 Disassembly for cleaning, Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 14、 1の画像 1
    • Remove the heating coil out of the heating component.
  15. Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 15、 3の画像 1 Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 15、 3の画像 2 Nostalgia Electrics RHP-310 Disassembly for cleaning: 手順 15、 3の画像 3
    • Visually check for debris.
    • Remove debris.
終わりに
作成者
3人の作成者と共同で作成されました。
Dana Clarke
メンバー登録日: 09/26/12
50 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S16G57
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,341
