はじめに
Use this guide to replace the motor in the cotton candy maker if it has gone bad.
必要な工具と部品
First, place the device on its side, making sure the switch is not facing down.
Remove the eight 12mm Phillips #02 screws from the base.
Locate the tie strap holding the wires and cut with a pair of scissors.
2件のガイドコメント
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
