メインコンテンツにスキップ
Nostalgia Chocolate Fondue Fountain CFF965 Disassembly
必要な工具と部品
  1. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly, Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 1、 1の画像 1
    • Lift the tiered tower away from the base bowl with your hands to remove it.
  2. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 2、 2の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 2、 2の画像 2
    • Lift the auger up and away from the base bowl by hand to remove it.
  3. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 3、 1の画像 1
    • Flip the base over.
    • Unscrew the 21.3 mm "feet" screws by hand.
  4. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 4、 3の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 4、 3の画像 2 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 4、 3の画像 3
    • Unscrew the three 14.2 mm screws with a Phillips #2 screwdriver.
    • Unscrew the 9.1 mm screw near the switch with a Phillips #2 screwdriver.
    • Unscrew the two 14.2 mm spanner screws using a spanner screwdriver (size 6).
  5. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 5、 2の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 5、 2の画像 2
    • Pull up on the baseplate by hand to remove it.
    • Pull the switch component up by hand.
  6. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 6、 1の画像 1
    • Unscrew the two 22.1 mm machine screws that secure the motor with a Phillips #2 screwdriver.
    • Remove their adjoining 5.9 mm washers by hand.
  7. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 7、 3の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 7、 3の画像 2 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 7、 3の画像 3
    • Unscrew the three 25.4 mm Phillips #2 sheet metal screws that connect the base bowl to the white plastic structure.
    • When unscrewing, make sure to hold the metal tower studs on the opposite side of the base bowl (see the second picture). This will make it easier to unscrew the screws.
    • Flip the base over and remove the base bowl by hand.
  8. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 8、 2の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 8、 2の画像 2
    • Flip the base over again to view the motor and fan.
    • Unscrew the remaining four 14.2 mm Phillips #2 sheet metal screws on the white plastic structure.
  9. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 9、 3の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 9、 3の画像 2 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 9、 3の画像 3
    • Flip the entire base over.
    • Lift up the metal heater plate by hand.
    • Remove the top of the white plastic box by hand.
    • The top of the white box should have a white gear and metal axis attached as well.
  10. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the yellow gear.
    • You can use your hands, but we recommend tweezers to avoid touching the lubrication.
  11. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 11、 1の画像 1
    • Unscrew the four 9.1 mm Phillips #2 sheet metal screws.
  12. Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 12、 3の画像 1 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 12、 3の画像 2 Nostalgia Chocolate Fondue Fountain CFF965 Disassembly: 手順 12、 3の画像 3
    • Remove the motor by hand.
終わりに
作成者
3人の作成者と共同で作成されました。
Caitlin Goldberg
メンバー登録日: 09/16/20
205 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 1,163
