メインコンテンツにスキップ
Nortel Networks i2004 IP Circuit Board Replacement
必要な工具と部品
  1. Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: 手順 1、 3の画像 1 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: 手順 1、 3の画像 2 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: 手順 1、 3の画像 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Circuit Board Replacement: 手順 2、 1の画像 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Circuit Board Replacement: 手順 3、 2の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 3、 2の画像 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Circuit Board Replacement: 手順 4、 1の画像 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Circuit Board Replacement: 手順 5、 2の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 5、 2の画像 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Circuit Board Replacement, Circuit Board: 手順 6、 1の画像 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Circuit Board Replacement: 手順 7、 2の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 7、 2の画像 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Circuit Board Replacement: 手順 8、 1の画像 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Circuit Board Replacement: 手順 9、 2の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 9、 2の画像 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Circuit Board Replacement: 手順 10、 3の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 10、 3の画像 2 Nortel Networks i2004 IP Circuit Board Replacement: 手順 10、 3の画像 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Circuit Board Replacement: 手順 11、 2の画像 1 Nortel Networks i2004 IP Circuit Board Replacement: 手順 11、 2の画像 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Circuit Board Replacement: 手順 12、 1の画像 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Circuit Board Replacement: 手順 13、 1の画像 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Elizabeth
メンバー登録日: 01/21/12
175 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G35
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 2,339
