メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Flip the phone over to view the back. Remove the power and phone cords. Remove the power and phone cords.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Remove the seven 8mm Phillips #2 screws.
    • Remove the seven 8mm Phillips #2 screws.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Lift up the back cover slowly because there are still wires attached to the circuit board. Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  5. Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  6. Remove the six 8mm Phillips #2 screws. Pull the speaker phone cover straight up.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
まとめ
ある他の人がこのガイドを完成しました。
Elizabeth
メンバー登録日: 2012年01月21日
160 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G35
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 1,006
