はじめに
This guide will show you how to remove and replace the cover of your Nook HD+.
パーツ
パーツは必要ありません。
  1. Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame. Note there will be glue and be careful not to brake the clips. Note there will be glue and be careful not to brake the clips.
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to brake the clips.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Apply glue round the inside perimeter of the new frame on the clip side.
    • Apply glue round the inside perimeter of the new frame on the clip side.
  4. Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
まとめ
Alex Pelicas
メンバー登録日: 2014年10月17日
259 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G3
5 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 545
