はじめに
Steps to replace a broken speaker in the Nook HD+ tablet.
パーツ
パーツは必要ありません。
  1. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Carefully remove the bottom frame from center chassis. Detach the battery ribbon from the motherboard.
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  5. In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
まとめ
ある他の人がこのガイドを完成しました。
Alex Pelicas
メンバー登録日: 2014年10月17日
259 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G3
5 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 494
