メインコンテンツにスキップ
Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement
必要な工具と部品
  1. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Back Cover Removal: 手順 1、 1の画像 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Battery Removal: 手順 2、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Battery Removal: 手順 2、 2の画像 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 1: 手順 3、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 1: 手順 3、 2の画像 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: 手順 4、 3の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: 手順 4、 3の画像 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Screen Separation part 2: 手順 4、 3の画像 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, System components: 手順 5、 1の画像 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: 手順 6、 3の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: 手順 6、 3の画像 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Motherboard Connector Removal: 手順 6、 3の画像 3
    この手順で使用する道具:
    • With tweezers, gently undo the motherboard connector for the vibrator, headphone jack and camera flash assembly.
  7. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 1: 手順 7、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 1: 手順 7、 2の画像 2
    • With tweezers, gently pry upward on the rectangular metal piece on the back of the camera flash.
  8. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 2: 手順 8、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 2: 手順 8、 2の画像 2
    • With tweezers, gently pry upward on the vibrator.
  9. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 3: 手順 9、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 3: 手順 9、 2の画像 2
    • With tweezers, gently pry upward on the headphone jack.
  10. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 4: 手順 10、 2の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 4: 手順 10、 2の画像 2
    • With tweezers, gently pry up on the proximity sensor.
  11. Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: 手順 11、 3の画像 1 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: 手順 11、 3の画像 2 Nokia XL Dual SIM Vibrator, Headphone Jack, or Camera Flash Components Replacement, Assembly Removal Pt. 5: 手順 11、 3の画像 3
    • The entire assembly can now be removed.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Leonardo Jaramillo
メンバー登録日: 09/25/14
87 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G4
3 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 2,846
