メインコンテンツにスキップ
Nokia X Rear-Facing Camera Replacement
必要な工具と部品
  1. Nokia X Rear-Facing Camera Replacement, Battery: 手順 1、 1の画像 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Rear-Facing Camera Replacement: 手順 2、 1の画像 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Rear-Facing Camera Replacement: 手順 3、 1の画像 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Rear-Facing Camera Replacement, Display Assembly: 手順 4、 2の画像 1 Nokia X Rear-Facing Camera Replacement, Display Assembly: 手順 4、 2の画像 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Rear-Facing Camera Replacement: 手順 5、 2の画像 1 Nokia X Rear-Facing Camera Replacement: 手順 5、 2の画像 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Rear-Facing Camera Replacement: 手順 6、 1の画像 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
  7. Nokia X Rear-Facing Camera Replacement, Remove Camera: 手順 7、 3の画像 1 Nokia X Rear-Facing Camera Replacement, Remove Camera: 手順 7、 3の画像 2 Nokia X Rear-Facing Camera Replacement, Remove Camera: 手順 7、 3の画像 3
    • Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
    • Remove the camera module by merely picking it up out of its housing slot.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Avery Dorsey
メンバー登録日: 01/21/15
1,894 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G1
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 984
