メインコンテンツにスキップ
Nokia X Headphone Jack Replacement
必要な工具と部品
  1. Nokia X Headphone Jack Replacement, Battery: 手順 1、 1の画像 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Headphone Jack Replacement: 手順 2、 1の画像 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Headphone Jack Replacement: 手順 3、 1の画像 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Headphone Jack Replacement, Display Assembly: 手順 4、 2の画像 1 Nokia X Headphone Jack Replacement, Display Assembly: 手順 4、 2の画像 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Headphone Jack Replacement: 手順 5、 2の画像 1 Nokia X Headphone Jack Replacement: 手順 5、 2の画像 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Headphone Jack Replacement: 手順 6、 1の画像 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
  7. Nokia X Headphone Jack Replacement, Headphone Jack: 手順 7、 2の画像 1 Nokia X Headphone Jack Replacement, Headphone Jack: 手順 7、 2の画像 2
    • Using the flat end of the spudger tool, unhook the two connectors connecting the audio jack to the motherboard.
    • The top connecter is attached via an adhesive as well, it will require a little bit of force to remove it.
  8. Nokia X Headphone Jack Replacement: 手順 8、 3の画像 1 Nokia X Headphone Jack Replacement: 手順 8、 3の画像 2 Nokia X Headphone Jack Replacement: 手順 8、 3の画像 3
    • Gently insert the pointed end of the spudger tool into the audio jack and lightly press upwards until the jack snaps loose.
    • It will take a bit of force to disconnect the biggest circuit from the motherboard as it is attached via an adhesive.
終わりに
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Avery Dorsey
メンバー登録日: 01/21/15
1,894 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G1
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 3,418
