メインコンテンツにスキップ
Nokia Windows 8 Phone All Models - Factory Reset
ビデオの概要
  1. Nokia Windows 8 Phone All Models - Factory Reset, Nokia Windows 8 Phone All Models - Factory Reset: 手順 1、 3の画像 1 Nokia Windows 8 Phone All Models - Factory Reset, Nokia Windows 8 Phone All Models - Factory Reset: 手順 1、 3の画像 2 Nokia Windows 8 Phone All Models - Factory Reset, Nokia Windows 8 Phone All Models - Factory Reset: 手順 1、 3の画像 3
    • Turn off the phone.
    • Press and hold the Volume Down and the Power buttons.
    • When you feel a vibration, release only the Power button,
    • or,
    • press and hold the Volume down button and connect the charger.
    • You will see an exclamation mark.
    Dont get exclimation point only nokia label looping
    aleximarymurphy - 返信
    The Gear start turning and then just stop screen goes black then goes back to lock screen
    Phillip Mason - 返信
  2. Nokia Windows 8 Phone All Models - Factory Reset: 手順 2、 3の画像 1 Nokia Windows 8 Phone All Models - Factory Reset: 手順 2、 3の画像 2 Nokia Windows 8 Phone All Models - Factory Reset: 手順 2、 3の画像 3
    • Press the keys in this order:
    • Volume Up
    • Volume Down
    • Power
    • Volume Down
    • The phone will reset and restart. This may take a few minutes.
    • Did you do it successfully?
    Worked perfectly. Thanks so much!
    kellykent - 返信
    It doesn't work for mine.
    Sibusiso Dangazela - 返信
    I try to press but com out the Goodbye not the watermark please help me how can I fixed my Nokia phone
    Renansa - 返信
    Thanks...it worked
    Dennis Bonnah - 返信
    Thanks. Perfectly well!! God Bless.
    tobertmuhairwe - 返信
    Thanks. Perfectly well. God bless.
    tobertmuhairwe - 返信
    tobertmuhairwe - 返信
    Can't work on lumia 625
    Palmer Delroy - 返信
    Worked for me too but took a little longer than I expected
    Ian Ingleby - 返信
    Thanks alot
    It has worked out successfully
    Lapolo Joseph Ochora - 返信
    power button is broken of Nokia Lumia 1320 is there any other way to do it
    Ritesh Shriwas - 返信
    It does not work on my phone
    alstephen2003 - 返信
    GOLD - 2 Thumbs up
    Mark Favetta - 返信
    cok guzel cok mersi
    mcoban184 - 返信
    Wow it really worked great! Easy as 123 Thanks
    bellabellaberrios - 返信
    It worked,am so happy
    Edionwe christabel - 返信
    Thank you so much. Xmas,. Soon.
    Donald Campbell - 返信
終わりに
If it doesn't work, try the procedure again.
48 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,368 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,468のガイドは作成済み
22 件のコメント
dint work still asking for password to unlock the phone
Shonna Milam - 返信
i just got my cell second hand i found it on the skytrain it says no sim but its locked how can i us this phone then i need hrlp
Peter Stevens -
It was excellent but I lost all my files so how do I retrieve my file back
Klutse Godson - 返信
It worked perfectly great thanks a lot I'm glad it helped me out
Victor Mobidyke - 返信
Het werkte prima, dankjewel voor deze gouden tip!
Nirana - 返信
did not work asking reset protection key microsoft lumia640
shafeeksona - 返信
my phone hard reaset after restarting ask reset protection key
shafeeksona - 返信
Phone doesn’t work even after a hard reset. It goes to Nokia logo, Windows logo & then to a grey screen and thats as far as l get. Any help?
Jonathan - 返信
How to set to my website?
Ruth Korth - 返信
did not work for my nokia carl zeiss tessar 2.2 28
nikolai1978 - 返信
how can i get past reset protection code if i dont know it stuck after reset
mr. peabody - 返信
Still did not work
Melissa Alardin - 返信
!&&* Yeh!!! Cheers 4 that. Spot on worked 1st time.
gary preston - 返信
It did not work with the volume down and start button method. But it did work when I tried with the volume down and connect the Charger method. Thanks!
Lyndsey Weeda - 返信
When a factory reset my phone. Now it's calling for a? Recovery key And I can't get into my phone. What do I do?
henrietta lankford - 返信
It says fastboot mode
Cayetano Chavez III - 返信
Estou precisando de ajuda para formatar Nokia Lumia
Joca Nascimento Silva - 返信
Nokia Lumia 1230 eu acho que esse é o modelo.
Nokia Lumia 1230 I think this is the model.
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 36
過去 30 日: 173
今までの合計 79,148
