メインコンテンツにスキップ
Nokia N900 Camera Replacement
必要な工具と部品
  1. Nokia N900 Camera Replacement, Camera: 手順 1、 1の画像 1
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
  2. Nokia N900 Camera Replacement: 手順 2、 1の画像 1
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
  3. Nokia N900 Camera Replacement: 手順 3、 1の画像 1
    • Remove the battery
  4. Nokia N900 Camera Replacement: 手順 4、 1の画像 1
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
  5. Nokia N900 Camera Replacement: 手順 5、 1の画像 1
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
  6. Nokia N900 Camera Replacement: 手順 6、 1の画像 1
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
  7. Nokia N900 Camera Replacement: 手順 7、 1の画像 1
    • Here are the two main pieces of the camera.
  8. Nokia N900 Camera Replacement: 手順 8、 1の画像 1
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Juan Haro
メンバー登録日: 03/13/14
284 ポイント
2のガイドは作成済み
チーム
New Mexico State, Team 1-4, Easley Spring 2014 New Mexico State, Team 1-4, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G4
4 メンバー
4のガイドは作成済み
コメント 1 件
Where to find a camera part ?
Thanks
François Soltic - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,194
