はじめに
This guide will show you how to replace the rear facing camera on your device. It has two prerequisite guides. They will show you how to remove the back cover and the motherboard, which will then let you gain access to the rear facing camera. It involves removing some screws, keeping track of a couple different connectors that have to be removed, and patience.
必要な工具と部品
Power down the phone.
There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
Remove the sim card tray on the top of the phone.
Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
Once all the clips are released, remove the back cover of the phone.
Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
Lift up the connector for the rear facing camera using the plastic opening tool.
