メインコンテンツにスキップ
Nokia Lumia 928 Back Cover Replacement
必要な工具と部品
  1. Nokia Lumia 928 Back Cover Replacement, Back Cover: 手順 1、 2の画像 1 Nokia Lumia 928 Back Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Back Cover Replacement: 手順 2、 3の画像 1 Nokia Lumia 928 Back Cover Replacement: 手順 2、 3の画像 2 Nokia Lumia 928 Back Cover Replacement: 手順 2、 3の画像 3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
終わりに
作成者
2人の作成者と共同で作成されました。
Curtis Dawe
メンバー登録日: 03/04/16
461 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 UMass Dartmouth, Team 6-8, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G8
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 12
今までの合計 708
