この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove the back panel to access the internal components of your Nokia Lumia 920.
必要な工具と部品
Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
14 の人々がこのガイドを完成させました。
