メインコンテンツにスキップ
Nokia Lumia 920 Back panel Replacement
必要な工具と部品
  1. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 手順 1、 3の画像 1 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 手順 1、 3の画像 2 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: 手順 1、 3の画像 3
    • Make sure the phone is off.
    • Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
  2. Nokia Lumia 920 Back panel Replacement: 手順 2、 2の画像 1 Nokia Lumia 920 Back panel Replacement: 手順 2、 2の画像 2
    • Use the smallest Torx screwdriver or another small poking tool and push into the hole on the SIM card slot. The plastic SIM protective piece should pop out quite easily.
    • Put that plastic piece aside.
  3. Nokia Lumia 920 Back panel Replacement: 手順 3、 2の画像 1 Nokia Lumia 920 Back panel Replacement: 手順 3、 2の画像 2
    • Once both screws on the bottom are removed, and the plastic SIM protective piece is removed, gently push on the outside of the screen.
    • The screen should become separated using little force. And should like the pictures shown once complete.
  4. Nokia Lumia 920 Back panel Replacement: 手順 4、 2の画像 1 Nokia Lumia 920 Back panel Replacement: 手順 4、 2の画像 2
    • This step may be easier to remove the battery first, but it is not mandatory.
    • Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
    • Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
  5. Nokia Lumia 920 Back panel Replacement: 手順 5、 2の画像 1 Nokia Lumia 920 Back panel Replacement: 手順 5、 2の画像 2
    • Once the metal clip is removed, gently pry up on the ribbon cable connection, located underneath the metal clip you have just removed.
終わりに
14 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jonathan
メンバー登録日: 10/31/14
1,492 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 4-2, Miles Fall 2014 UMass Dartmouth, Team 4-2, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G2
2 メンバー
7のガイドは作成済み
コメント 1 件
useless - doesnt show detail
nick - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 9,497
