メインコンテンツにスキップ
Nokia Lumia 900 Speaker Replacement
必要な工具と部品
  1. Nokia Lumia 900 Speaker Replacement, Screen: 手順 1、 2の画像 1 Nokia Lumia 900 Speaker Replacement, Screen: 手順 1、 2の画像 2
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Speaker Replacement: 手順 2、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Speaker Replacement: 手順 3、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 3、 2の画像 2
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Speaker Replacement: 手順 4、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 4、 2の画像 2
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Speaker Replacement: 手順 5、 1の画像 1
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
  6. Nokia Lumia 900 Speaker Replacement, Front Camera: 手順 6、 2の画像 1 Nokia Lumia 900 Speaker Replacement, Front Camera: 手順 6、 2の画像 2
    • Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
    • Use the plastic opening tools to carefully lift the front camera from the motherboard.
  7. Nokia Lumia 900 Speaker Replacement, Battery: 手順 7、 2の画像 1 Nokia Lumia 900 Speaker Replacement, Battery: 手順 7、 2の画像 2
    • Use the flat end of a spudger to carefully disconnect the ribbon cable.
    • Make sure not to bend or crease the cable.
  8. Nokia Lumia 900 Speaker Replacement: 手順 8、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to remove the battery.
    • The battery may be glued down. This will be evident if the battery is difficult to lift. Use the iFixit iOpener to heat the back of the phone allowing the glue to heat and become more pliable before trying to lift the battery again. This may take several minutes.
  9. Nokia Lumia 900 Speaker Replacement, Speaker: 手順 9、 2の画像 1 Nokia Lumia 900 Speaker Replacement, Speaker: 手順 9、 2の画像 2
    • Use the plastic opening tool to lift the orange ribbon cable from the motherboard.
  10. Nokia Lumia 900 Speaker Replacement: 手順 10、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 10、 2の画像 2
    • Use the plastic opening tool to lift the motherboard out of the casing.
    • It is recommended that you wedge the opening tool in the crevice between the motherboard and casing in the top righthand corner of the device.
  11. Nokia Lumia 900 Speaker Replacement: 手順 11、 1の画像 1
    • Use the flat end of a spudger to lift the LED out of the casing.
  12. Nokia Lumia 900 Speaker Replacement: 手順 12、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 12、 2の画像 2
    • Use the flat end of a spudger to lift the metal backplate from the casing.
    • Be sure not to lose the buttons.
  13. Nokia Lumia 900 Speaker Replacement: 手順 13、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 13、 2の画像 2
    • Wedge the pointed end of the spudger into the gaps in the antenna housing and pull the antenna housing away from the casing walls.
  14. Nokia Lumia 900 Speaker Replacement: 手順 14、 2の画像 1 Nokia Lumia 900 Speaker Replacement: 手順 14、 2の画像 2
    • Insert the pointed end of the spudger into the hole and slide the speaker housing out from the casing.
終わりに
作成者
2人の作成者と共同で作成されました。
Kourtney Collier
メンバー登録日: 03/31/22
289 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 3-2, Harley Spring 2022 IUPUI, Team 3-2, Harley Spring 2022人のメンバー
IUPUI-HARLEY-S22S3G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 107
