メインコンテンツにスキップ
Nokia Lumia 635 630 Display Assembly Replacement with Frame
必要な工具と部品
ビデオの概要
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 手順 1、 3の画像 1 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 手順 1、 3の画像 2 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 手順 1、 3の画像 3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 2、 3の画像 1 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 2、 3の画像 2 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 2、 3の画像 3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
    You need a decent quality T4 screwdriver here - the rubbish on that cm free with the screen assembly I bought failed completely to grip or loosen the screws. With one from a decent set (ForgeSteel from ScrewFix) they came out easily. A fridge magnet is useful to keep the screws on.
    jeremyyoung - 返信
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 3、 3の画像 1 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 3、 3の画像 2 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 手順 3、 3の画像 3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 手順 4、 3の画像 1 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 手順 4、 3の画像 2 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 手順 4、 3の画像 3
    • Put the earpiece on the new display assembly and start with reassembling.
終わりに
17 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,532のガイドは作成済み
2 件のコメント
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - 返信
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 10,325
