メインコンテンツにスキップ
はじめに
How to disassemble the Nokia Lumia 625 and change broken Touch screen Glass.
ビデオの概要
  1. Turn off the phone and remove the back cover. Remove any installed SIM or memory card. Use a screwdriver Torx T5 and remove the 8x black screws.
    • Turn off the phone and remove the back cover.
    • Remove any installed SIM or memory card.
    • Use a screwdriver Torx T5 and remove the 8x black screws.
  2. At the top and bottom of the phone you'll see two grooves. Use a plastic tool and start the separating the rear bezel from here. Use a plastic tool and start the separating the rear bezel from here.
    • At the top and bottom of the phone you'll see two grooves.
    • Use a plastic tool and start the separating the rear bezel from here.
  3. Disconnect the battery and the touch screen flex cables. Now is the moment for test the new spare part. Finally, disconnect the battery again and remove the new touch screen.
    • Disconnect the battery and the touch screen flex cables.
    • Now is the moment for test the new spare part.
    • Finally, disconnect the battery again and remove the new touch screen.
  4. Put some scotch tape to prevent the glass from shattering and yourself from injury. Use a hair dryer and warm the glass to make adhesive soften.
    • Put some scotch tape to prevent the glass from shattering and yourself from injury.
    • Use a hair dryer and warm the glass to make adhesive soften.
  5. With a cutter separate the glass a little bit to make a room for the plastic pick or other plastic tool. Be careful for the LCD. You can use a hair dryer again to rewarm the glass. Be careful for the LCD. You can use a hair dryer again to rewarm the glass.
    • With a cutter separate the glass a little bit to make a room for the plastic pick or other plastic tool.
    • Be careful for the LCD. You can use a hair dryer again to rewarm the glass.
  6. Clean the frame of the old adhesive tape and install new. Clean the frame of the old adhesive tape and install new. Clean the frame of the old adhesive tape and install new.
    • Clean the frame of the old adhesive tape and install new.
  7. Check the LCD for dust and install the new touch screen glass. Now reassemble the phone. Now reassemble the phone.
    • Check the LCD for dust and install the new touch screen glass.
    • Now reassemble the phone.
終わりに
19 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
179,145 ポイント
316のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
300 メンバー
990のガイドは作成済み
4 件のコメント
Thanks for this guide!
However, the phone uses T5 screws. The T4 screwdriver would simply damage the screws. Just that advice.
Thanks again for such detailed guide.
carlitossuper1 - 返信
Another comment: I was attempting to do this guide and the LCD is glued to the digitizer! It's very important to disclose this at the beginning of the guide. You could end up with a broken LCD!
Do not try this if the original glass broke, because it's glued to the LCD and removing the broken glass could damage it.
carlitossuper1 - 返信
That is not true carlitossuper1, the LCD and the digitizer are not fised together. Glue is only around the frame.
Andrzej Grabowski - 返信
I managed to replace the original digitizer as well. This was my first digitizer replacement and it took me 1 h 45 min the starting point being: this guide open, tools available, replacement part and the smart phone in hand. The operation itself took me some 35 min.
About the screws: I used T4 (I read the comments only afterwards), didn't slip a bit, but T5 fits better now that I tried it.
What a great feeling! I achieved something very concrete today - thanks to you!
Sampo Kouri - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 6,983
