メインコンテンツにスキップ
Nokia Lumia 625 Touch Screen Digitizer Glass Replacement
必要な工具と部品
ビデオの概要
  1. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Rear Bezel: 手順 1、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Rear Bezel: 手順 1、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Rear Bezel: 手順 1、 3の画像 3
    • Turn off the phone and remove the back cover.
    • Remove any installed SIM or memory card.
    • Use a screwdriver Torx T5 and remove the 8x black screws.
  2. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 2、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 2、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 2、 3の画像 3
    • At the top and bottom of the phone you'll see two grooves.
    • Use a plastic tool and start the separating the rear bezel from here.
  3. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Touch Screen Digitizer Glass: 手順 3、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Touch Screen Digitizer Glass: 手順 3、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement, Touch Screen Digitizer Glass: 手順 3、 3の画像 3
    • Disconnect the battery and the touch screen flex cables.
    • Now is the moment for test the new spare part.
    • Finally, disconnect the battery again and remove the new touch screen.
  4. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 4、 2の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 4、 2の画像 2
    • Put some scotch tape to prevent the glass from shattering and yourself from injury.
    • Use a hair dryer and warm the glass to make adhesive soften.
  5. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 5、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 5、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 5、 3の画像 3
    • With a cutter separate the glass a little bit to make a room for the plastic pick or other plastic tool.
    • Be careful for the LCD. You can use a hair dryer again to rewarm the glass.
  6. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 6、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 6、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 6、 3の画像 3
    • Clean the frame of the old adhesive tape and install new.
  7. Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 7、 3の画像 1 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 7、 3の画像 2 Nokia Lumia 625 Touch Screen Digitizer Glass Replacement: 手順 7、 3の画像 3
    • Check the LCD for dust and install the new touch screen glass.
    • Now reassemble the phone.
終わりに
20 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
4 件のコメント
Thanks for this guide!
However, the phone uses T5 screws. The T4 screwdriver would simply damage the screws. Just that advice.
Thanks again for such detailed guide.
carlitossuper1 - 返信
Another comment: I was attempting to do this guide and the LCD is glued to the digitizer! It's very important to disclose this at the beginning of the guide. You could end up with a broken LCD!
Do not try this if the original glass broke, because it's glued to the LCD and removing the broken glass could damage it.
carlitossuper1 - 返信
That is not true carlitossuper1, the LCD and the digitizer are not fised together. Glue is only around the frame.
Andrzej Grabowski - 返信
I managed to replace the original digitizer as well. This was my first digitizer replacement and it took me 1 h 45 min the starting point being: this guide open, tools available, replacement part and the smart phone in hand. The operation itself took me some 35 min.
About the screws: I used T4 (I read the comments only afterwards), didn't slip a bit, but T5 fits better now that I tried it.
What a great feeling! I achieved something very concrete today - thanks to you!
Sampo Kouri - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 7,338
