Switch off the phone, remove the battery and SIM (Memory) card.
The lower back cover is held by 3x T4 Torx screws.
The screws are of two types!
If you want to replace the Digitizer, let's test the spare part first.
Be careful, don't break the flex cable.
If you have not yet disconnected the Digitizer and the Touch screen flex cables, do it now.
The Logic Board is held to the Middle frame by two plastic clips.
Now gently remove the LCD Display.
If you have a broken LCD, replace it and reassemble the phone.
We will continue with removing the Touch screen Glass.
Put a scotch tape to prevent the glass from scattering.
With a hot air warm the glass to soften the adhesive.
You can use a hair dryer for this operation.
Start with separating at the middle, where the bonded area is smaller.
Clean the remnants of the old adhesive tape.
If the spare parts come without adhesive tape, you must put by himself.
Prepare the new digitizer glass and install it.
Reassemble the device.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
