メインコンテンツにスキップ
Nokia Lumia 521 Audio Jack Replacement
必要な工具と部品
  1. Nokia Lumia 521 Audio Jack Replacement, Battery: 手順 1、 2の画像 1 Nokia Lumia 521 Audio Jack Replacement, Battery: 手順 1、 2の画像 2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Audio Jack Replacement: 手順 2、 1の画像 1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 Audio Jack Replacement, SIM Card: 手順 3、 1の画像 1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
  4. Nokia Lumia 521 Audio Jack Replacement, Motherboard: 手順 4、 2の画像 1 Nokia Lumia 521 Audio Jack Replacement, Motherboard: 手順 4、 2の画像 2
    • Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
    • Five 5 mm screws.
    • Four 4 mm screws.
  5. Nokia Lumia 521 Audio Jack Replacement: 手順 5、 2の画像 1 Nokia Lumia 521 Audio Jack Replacement: 手順 5、 2の画像 2
    • Using a plastic opening tool, pry apart the inner back case apart from the rest of the phone, starting at the top and prying while going around the phone.
  6. Nokia Lumia 521 Audio Jack Replacement: 手順 6、 2の画像 1 Nokia Lumia 521 Audio Jack Replacement: 手順 6、 2の画像 2
    • Unclasp the motherboard from the black case clasps using a plastic opening tool.
  7. Nokia Lumia 521 Audio Jack Replacement: 手順 7、 2の画像 1 Nokia Lumia 521 Audio Jack Replacement: 手順 7、 2の画像 2
    • Unclip the motherboard clasps using your fingers or a plastic opening tool.
  8. Nokia Lumia 521 Audio Jack Replacement, Audio Jack: 手順 8、 1の画像 1
    • Use the plastic opening tool to pry the audio jack loose.
  9. Nokia Lumia 521 Audio Jack Replacement: 手順 9、 1の画像 1
    • After prying the audio jack loose, use the plastic opening tool to remove the connective tab.
終わりに
作成者
2人の作成者と共同で作成されました。
Selamawi Ambaye
メンバー登録日: 02/10/16
261 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 11
今までの合計 306
