メインコンテンツにスキップ
Nokia Lumia 520 Power/Volume Switch Replacement
必要な工具と部品
  1. Nokia Lumia 520 Power/Volume Switch Replacement, Battery: 手順 1、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement, Battery: 手順 1、 2の画像 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 2、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement: 手順 2、 2の画像 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 3、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement: 手順 3、 2の画像 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 手順 4、 3の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 手順 4、 3の画像 2 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 手順 4、 3の画像 3
    • Unscrew the 8 screws with a Torx screw driver (T4). After all screws are unscrewed place them next to the phone in the order
  5. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 5、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement: 手順 5、 2の画像 2
    • Use your spudger to remove the plastic casing over the motherboard. Do it very slowly because it will be tough to remove and you do not want to break it.
  6. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 6、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement: 手順 6、 2の画像 2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using a spudger.
  7. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 7、 2の画像 1 Nokia Lumia 520 Power/Volume Switch Replacement: 手順 7、 2の画像 2
    • Gently remove the motherboard with your hands.
    • Flip it over and turn it 90 degrees to the left so the buttons are in front of you.
    • You will see four small switches close to the side of the circuit board.
  8. Nokia Lumia 520 Power/Volume Switch Replacement: 手順 8、 1の画像 1
    • Gently take the power/volume switches off using a pair of needle nose pliers. Gently clean the solder that was there. Replace the solder with a new coat of solder.
    • Check out iFixit's soldering guides, here.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Eduardo Perez
メンバー登録日: 11/03/15
189 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015人のメンバー
UMASSD-BHUSAL-F15S1G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 19
今までの合計 5,541
