メインコンテンツにスキップ
Nokia Lumia 1020 Front-Facing Camera Replacement
必要な工具と部品
  1. Nokia Lumia 1020 Front-Facing Camera Replacement, Screen: 手順 1、 2の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement, Screen: 手順 1、 2の画像 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 2、 3の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 2、 3の画像 2 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 2、 3の画像 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 3、 3の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 3、 3の画像 2 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 3、 3の画像 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 4、 3の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 4、 3の画像 2 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 4、 3の画像 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 2 Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: 手順 5、 3の画像 3
    • Wedge a spudger underneath front-facing camera on the upper left corner of the screen. Pry upwards until it pops up to the right.
  6. Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 6、 3の画像 1 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 6、 3の画像 2 Nokia Lumia 1020 Front-Facing Camera Replacement: 手順 6、 3の画像 3
    • Wedge a spudger underneath the silver rectangle to the right of the front-facing camera. Pry upwards until it pops off.
    • Remove the camera.
終わりに
作成者
2人の作成者と共同で作成されました。
Sydney Hostelley
メンバー登録日: 02/15/18
614 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G4, Leahy Spring 2018 USF Tampa, Team S1-G4, Leahy Spring 2018人のメンバー
USFT-LEAHY-S18S1G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 407
