メインコンテンツにスキップ
Nokia Lumia 1020 Charging Port Replacement
必要な工具と部品
  1. Nokia Lumia 1020 Charging Port Replacement, Screen: 手順 1、 2の画像 1 Nokia Lumia 1020 Charging Port Replacement, Screen: 手順 1、 2の画像 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Charging Port Replacement: 手順 2、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 2、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 2、 3の画像 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Charging Port Replacement: 手順 3、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 3、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 3、 3の画像 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Charging Port Replacement: 手順 4、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 4、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 4、 3の画像 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Charging Port Replacement, Battery: 手順 5、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement, Battery: 手順 5、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement, Battery: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Unscrew the two 4 mm torx screws on the top silver strip with a T4 screwdriver.
    • Unscrew the 4.5 mm torx screw above the gold bar with a T6 screwdriver.
    • Grab the edges of the gold strip with gripped tweezers to remove. The gold and silver metal will come off together.
  6. Nokia Lumia 1020 Charging Port Replacement: 手順 6、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 6、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 6、 3の画像 3
    • Be careful not to puncture the battery. Use a spudger to slice the black tape on the left side of the battery.
    • Remove the battery with your finger.
    • Wedge a spudger underneath the small black rectangle attached to the battery until it pops off.
  7. Nokia Lumia 1020 Charging Port Replacement, Headphone Jack: 手順 7、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement, Headphone Jack: 手順 7、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement, Headphone Jack: 手順 7、 3の画像 3
    • Use the T4 screwdriver to remove the 4 mm torx screw.
    • Remove the headphone jack by pulling back on the silver plate with your fingernail.
  8. Nokia Lumia 1020 Charging Port Replacement: 手順 8、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 8、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 8、 3の画像 3
    • Remove the headphone jack with spudger.
    • Wedge the spudger underneath the grey rectangle and pry until it pops off. Note this piece is glued and may require more force than previous rectangles.
    • Headphone jack is fully removed and can be replaced.
  9. Nokia Lumia 1020 Charging Port Replacement, Rear-Facing Camera: 手順 9、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement, Rear-Facing Camera: 手順 9、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement, Rear-Facing Camera: 手順 9、 3の画像 3
    • Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
    • Remove the camera by wedging a spudger underneath the attached gold foil.
  10. Nokia Lumia 1020 Charging Port Replacement, Motherboard: 手順 10、 2の画像 1 Nokia Lumia 1020 Charging Port Replacement, Motherboard: 手順 10、 2の画像 2
    • Disconnect the two gold connectors from the motherboard using a spudger.
    • Be gentle with the connectors to make sure they are not damaged.
  11. Nokia Lumia 1020 Charging Port Replacement: 手順 11、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 11、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 11、 3の画像 3
    • Using a T4 screwdriver, remove four 4.60 mm screws to disconnect the motherboard from the rest of the device.
    • Be sure not to lose the screws.
  12. Nokia Lumia 1020 Charging Port Replacement: 手順 12、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 12、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 12、 3の画像 3
    • Use the spudger to remove motherboard first from the top right corner, then bottom right corner, then the bottom left corner.
    • After loosening the motherboard, begin to remove the component by starting at the top right corner first, then pull motherboard out.
  13. Nokia Lumia 1020 Charging Port Replacement, Charging Port: 手順 13、 1の画像 1
    • Using a T4 screwdriver, unscrew four 4.60 mm screws to disconnect the rear camera casing from the rest of the device.
  14. Nokia Lumia 1020 Charging Port Replacement: 手順 14、 1の画像 1
    • Use a hairdryer to heat up the adhesive of the plastic base. This may take around 5 minutes.
    • This may take more than 5 minutes. Also, the iOpener by itself may not provide enough heat to truly melt the adhesive.
  15. Nokia Lumia 1020 Charging Port Replacement: 手順 15、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 15、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 15、 3の画像 3
    • Insert the spudger on the edges of the base and lift up.
  16. Nokia Lumia 1020 Charging Port Replacement: 手順 16、 2の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 16、 2の画像 2
    • Now that the base is loose, lift it with your fingers and separate it from the case.
  17. Nokia Lumia 1020 Charging Port Replacement: 手順 17、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 17、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 17、 3の画像 3
    • After removing the base, slide the spudger in underneath the speaker, and slide the spudger across.
    • The speaker and charging port assembly should then come out easily.
  18. Nokia Lumia 1020 Charging Port Replacement: 手順 18、 3の画像 1 Nokia Lumia 1020 Charging Port Replacement: 手順 18、 3の画像 2 Nokia Lumia 1020 Charging Port Replacement: 手順 18、 3の画像 3
    • Lastly, wedge the spudger on one side of the charging port and push out. Once it is loose, the charging port comes right out!
    • There are clips that you need to get past, so don't be afraid to push a little harder than normal.
    • The smaller piece from the disassembly is the charging port while the larger piece is the speaker.
終わりに
作成者
2人の作成者と共同で作成されました。
Abbi Waterfill
メンバー登録日: 11/04/19
354 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S1-G5, Henning Fall 2019 IUPUI, Team S1-G5, Henning Fall 2019人のメンバー
IUPUI-HENNING-F19S1G5
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 1,413
