メインコンテンツにスキップ
Nokia E90 Front Cover Replacement
必要な工具と部品
  1. Nokia E90 Front Cover Replacement, Front Cover: 手順 1、 1の画像 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Cover Replacement: 手順 2、 2の画像 1 Nokia E90 Front Cover Replacement: 手順 2、 2の画像 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Cameron Weinberg
メンバー登録日: 04/12/11
567 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G21
3 メンバー
8のガイドは作成済み
2 件のコメント
I have a n90 done which will not switch on. I have changed the battery and still nothing.pressing the top power button but nothing.trying to get old pics off the phone any help?
Smith - 返信
Hello Mr Smith. Have you tried to recharge the battery as it is in the phone in question? Recharge the battery while it is in the phone first, IF the phone in question still does not boot up then get another battery from ebay. I have a similar E90 as yours and the battery did go flat in the end, like all batteries, I just got a new battery and then recharged the battery while it is in the phone. Good luck.
Keith N Searle -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 16
今までの合計 4,993
