この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the Nokia E61i screen.
必要な工具と部品
Remove the back cover to access the battery. Press the tab on the bottom of the cover.
Slide the back cover downwards off of the phone while pressing the tab down.
Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
After taking off the casing and keyboard, remove the screws holding the screen in place. Use a T-6 for the screws in the middle of the red circles, and use a T-5 for the screw in the middle of the red square.
Lift the ribbon off of the contact with the motherboard.
When reassembling, firmly press the contacts into place to connect the ribbon and the motherboard.
3 の人々がこのガイドを完成させました。
