メインコンテンツにスキップ
Nokia Asha 201 Screen Replacement
必要な工具と部品
  1. Nokia Asha 201 Screen Replacement, Screen: 手順 1、 1の画像 1
    • Remove back cover of device by pressing firmly and sliding the cover off.
  2. Nokia Asha 201 Screen Replacement: 手順 2、 1の画像 1
    • Using your finger, lift up on battery to remove from the device.
  3. Nokia Asha 201 Screen Replacement: 手順 3、 1の画像 1
    • Using a screwdriver, remove the two screws from the back case.
  4. Nokia Asha 201 Screen Replacement: 手順 4、 1の画像 1
    • Pry off the front case using a iFixit opening tool.
  5. Nokia Asha 201 Screen Replacement: 手順 5、 1の画像 1
    • Remove the Keyboard with your hands.
  6. Nokia Asha 201 Screen Replacement: 手順 6、 1の画像 1
    • Remove the four screws pictured here.
  7. Nokia Asha 201 Screen Replacement: 手順 7、 1の画像 1
    • Using the iFixit opening tool, separate the screen from motherboard.
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
  8. Nokia Asha 201 Screen Replacement: 手順 9、 1の画像 1
    • After plugging in the new screen put back the screen onto the motherboard.
  9. Nokia Asha 201 Screen Replacement: 手順 10、 1の画像 1
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
  10. Nokia Asha 201 Screen Replacement: 手順 11、 1の画像 1
    • Using your fingers place the keyboard back like in the picture.
  11. Nokia Asha 201 Screen Replacement: 手順 12、 1の画像 1
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
  12. Nokia Asha 201 Screen Replacement: 手順 13、 1の画像 1
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
  13. Nokia Asha 201 Screen Replacement: 手順 14、 1の画像 1
    • Using your fingers put back the battery in the back of the phone properly.
  14. Nokia Asha 201 Screen Replacement: 手順 15、 1の画像 1
    • Slide back in the phone cover to the back of the device.
終わりに
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Amanda Tresgallos
メンバー登録日: 10/10/19
158 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G3, Leahy Fall 2019 USF Tampa, Team S1-G3, Leahy Fall 2019人のメンバー
USFT-LEAHY-F19S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 609
