メインコンテンツにスキップ
Nokia 8290 Adhesive White Film Replacement
必要な工具と部品
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: 手順 1、 3の画像 1 Nokia 8290 Adhesive White Film Replacement, Front Cover: 手順 1、 3の画像 2 Nokia 8290 Adhesive White Film Replacement, Front Cover: 手順 1、 3の画像 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: 手順 2、 3の画像 1 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 手順 2、 3の画像 2 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 手順 2、 3の画像 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: 手順 3、 3の画像 1 Nokia 8290 Adhesive White Film Replacement: 手順 3、 3の画像 2 Nokia 8290 Adhesive White Film Replacement: 手順 3、 3の画像 3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 手順 4、 3の画像 1 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 手順 4、 3の画像 2 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 手順 4、 3の画像 3
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: 手順 5、 3の画像 1 Nokia 8290 Adhesive White Film Replacement: 手順 5、 3の画像 2 Nokia 8290 Adhesive White Film Replacement: 手順 5、 3の画像 3
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
終わりに
作成者
4人の作成者と共同で作成されました。
Austin Culberson
メンバー登録日: 10/22/12
87 ポイント
5のガイドは作成済み
チーム
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S15G3
3 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 371
