はじめに
How to remove the gold patch antenna.
パーツ
パーツは必要ありません。
  1. Turn off the cell phone.
    • Turn off the cell phone.
  2. Press down on the round button on the back cover of the phone.
    • Press down on the round button on the back cover of the phone.
  3. Slide the back cover down while still pressing the button.
    • Slide the back cover down while still pressing the button.
  4. Remove the back cover.
    • Remove the back cover.
  5. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  6. Press the end of the battery towards the top of the phone.
    • Press the end of the battery towards the top of the phone.
  7. Lift the battery outwards while still pressing it upwards till it pops out.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  8. Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  9. Pry open the antenna door by pulling down the top of the spudger
    • Pry open the antenna door by pulling down the top of the spudger
  10. Remove the antenna door.
    • Remove the antenna door.
  11. If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
まとめ
ある他の人がこのガイドを完成しました。
Aaron Jen
メンバー登録日: 2010年04月11日
1 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G94
4 メンバー
14のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,093
