メインコンテンツにスキップ
Nokia 6350-1b Logic board Replacement
必要な工具と部品
  1. Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: 手順 1、 2の画像 1 Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: 手順 1、 2の画像 2
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move it along the frame unlocking the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry to hard and crack the plastic frame.
  2. Nokia 6350-1b Logic board Replacement, Removing the screen cover: 手順 2、 3の画像 1 Nokia 6350-1b Logic board Replacement, Removing the screen cover: 手順 2、 3の画像 2 Nokia 6350-1b Logic board Replacement, Removing the screen cover: 手順 2、 3の画像 3
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move alone this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Logic board Replacement, Removing broken logic board: 手順 3、 3の画像 1 Nokia 6350-1b Logic board Replacement, Removing broken logic board: 手順 3、 3の画像 2 Nokia 6350-1b Logic board Replacement, Removing broken logic board: 手順 3、 3の画像 3
    • Disconnect the flex cable from the logic board.
    • Disconnect the camera from the logic board.
    • Disconnect the LCD display screen.
    • Disconnect the LCD phone screen.
    • Carefully remove the broken logic board by freeing it from the various locks holding it in place.
    • Be careful not to touch either of the screens. You can leave finger prints and damage the screens.
  4. Nokia 6350-1b Logic board Replacement, Replacing Logic Board: 手順 4、 2の画像 1 Nokia 6350-1b Logic board Replacement, Replacing Logic Board: 手順 4、 2の画像 2
    • Take the new logic board and connect all the parts you just disconnected to their correct locations.
  5. Nokia 6350-1b Logic board Replacement: 手順 5、 2の画像 1 Nokia 6350-1b Logic board Replacement: 手順 5、 2の画像 2
    • Place the cover so that it is in the correct position to be re-installed.
    • Press gently on the cover so that it snaps back into place.
終わりに
作成者
4人の作成者と共同で作成されました。
Adrianna
メンバー登録日: 04/18/12
36 ポイント
2のガイドは作成済み
チーム
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012人のメンバー
SUNYCORT-GETTO-S12S1G2
2 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,706
