メインコンテンツにスキップ
Nokia 6350-1b Battery Replacement
必要な工具と部品
  1. Nokia 6350-1b Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover of the phone by sliding it downwards.
    • This will be a thin panel that has three stripes to provide better grip.
  2. Nokia 6350-1b Battery Replacement: 手順 2、 1の画像 1
    • Caution: When you slide the panel downwards, it will immediately come loose.
    • Remove the BP-6MT battery. There should be an indent showing where you will lift.
  3. Nokia 6350-1b Battery Replacement: 手順 3、 1の画像 1
    • Once you have removed the old battery, you can begin to install the new battery.
    • Line up the gold indentations in the upper left corner of the battery with the three gold indentations in the upper left hand corner of the empty battery space.
  4. Nokia 6350-1b Battery Replacement: 手順 4、 1の画像 1
    • Ensure that when you have lined up the battery, you are able to seamlessly insert into phone.
    • Note: If it does not slide seamlessly, it is not being inserted correctly
  5. Nokia 6350-1b Battery Replacement: 手順 5、 1の画像 1
    • After the battery has clicked in, you need to reinstall the back panel of the phone.
    • Line the back panel up with the phone.
  6. Nokia 6350-1b Battery Replacement: 手順 6、 1の画像 1
    • Line up the back panel starting from the bottom.
    • Once lined and pressed down, slide upward. You should be able to feel and hear it click back into place.
終わりに
作成者
5人の作成者と共同で作成されました。
Anna
メンバー登録日: 04/13/12
21 ポイント
2のガイドは作成済み
チーム
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012人のメンバー
SUNYCORT-GETTO-S12S1G2
2 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 20
今までの合計 1,410
