メインコンテンツにスキップ
Nokia 6085h Keypad Replacement
必要な工具と部品
  1. Nokia 6085h Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Keypad Replacement: 手順 2、 1の画像 1
    • Remove the phone's battery.
  3. Nokia 6085h Keypad Replacement, Motherboard: 手順 3、 2の画像 1 Nokia 6085h Keypad Replacement, Motherboard: 手順 3、 2の画像 2
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Keypad Replacement: 手順 4、 1の画像 1
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Keypad Replacement: 手順 5、 1の画像 1
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Keypad Replacement: 手順 6、 2の画像 1 Nokia 6085h Keypad Replacement: 手順 6、 2の画像 2
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Keypad Replacement: 手順 7、 1の画像 1
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Keypad Replacement: 手順 8、 1の画像 1
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Keypad Replacement: 手順 9、 1の画像 1
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Keypad Replacement, Keypad: 手順 10、 1の画像 1
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Andrew
メンバー登録日: 10/04/10
397 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S4G46
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 2,351
