メインコンテンツにスキップ
Nokia 6010 vibrator motor replacement
必要な工具と部品
  1. Nokia 6010 vibrator motor replacement, Battery: 手順 1、 3の画像 1 Nokia 6010 vibrator motor replacement, Battery: 手順 1、 3の画像 2 Nokia 6010 vibrator motor replacement, Battery: 手順 1、 3の画像 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 vibrator motor replacement: 手順 2、 2の画像 1 Nokia 6010 vibrator motor replacement: 手順 2、 2の画像 2
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 vibrator motor replacement, SIM Card: 手順 3、 1の画像 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 vibrator motor replacement, Keypad: 手順 4、 2の画像 1 Nokia 6010 vibrator motor replacement, Keypad: 手順 4、 2の画像 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 vibrator motor replacement: 手順 5、 1の画像 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  6. Nokia 6010 vibrator motor replacement, LCD Screen and Speaker: 手順 6、 2の画像 1 Nokia 6010 vibrator motor replacement, LCD Screen and Speaker: 手順 6、 2の画像 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  7. Nokia 6010 vibrator motor replacement: 手順 7、 3の画像 1 Nokia 6010 vibrator motor replacement: 手順 7、 3の画像 2 Nokia 6010 vibrator motor replacement: 手順 7、 3の画像 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
  8. Nokia 6010 vibrator motor replacement, Logic Board: 手順 8、 2の画像 1 Nokia 6010 vibrator motor replacement, Logic Board: 手順 8、 2の画像 2
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
  9. Nokia 6010 vibrator motor replacement: 手順 9、 3の画像 1 Nokia 6010 vibrator motor replacement: 手順 9、 3の画像 2 Nokia 6010 vibrator motor replacement: 手順 9、 3の画像 3
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
  10. Nokia 6010 vibrator motor replacement, Vibrator: 手順 10、 3の画像 1 Nokia 6010 vibrator motor replacement, Vibrator: 手順 10、 3の画像 2 Nokia 6010 vibrator motor replacement, Vibrator: 手順 10、 3の画像 3
    • Insert a spudger beneath the metallic shaft of the vibrator and pry it away from the phone.
    • The vibrator is the small orange box located near the bottom of the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nicholas Hanne
メンバー登録日: 01/20/10
129 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G45
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 2,332
